Emai Photo Attachments
21 Mar 2004
Dorset
If I click on a photo attached to an email it always views it in the temporary folder in local settings and gets mixed up with loads of other temporary pictures from random web sites. How do I change te default settings so that the photo gets saved in a folder of my choice???
I think I know why joroma is asking this - It's annoying not to be able to flick through a bunch of photo's you've opened up from an email without trawling past loads of spurious graphics. Say you've opened up 10 photo's and want to look at them again - you have to re-open from the mail! Annoying...
Do you mean the viewer? Opening direct from email and usindgWindows to view the images?
Or are you saving them from the email first?
I mean the viewer. When you click on the attached photo it is opened in the temporary internet files folder so it is mixed in with hundreds of random images!!
