Email help, sending VM via O2 connection.
4 Feb 2007
Nuneaton, UK
I no longer have my Virgin Media internet connection but my email address still works receiving email but won't send via my O2 connection.
Is there anything I can do?
I tried using the O2 SMTP in the out going mail box but it says no relaying.
I don't think Virgin allow email to be sent from none VM IP addresses.
Any ideas?
Thanks
I believe O2 block port 25 unless you have a static IP address.
This was what I found when I was researching this issue when I switched to O2.
You can probably still use Virgin Media webmail from their website.
Ah, I don't have a static IP.
Never tried the webmail via the site before, still a pain.
Is there no other solution?
