email settings?
1 Jul 2007
I don't know if maybe Virgin Media has changed settings but I have my email set up across three devices.
Desktop,
Phone
Tablet
Receiving emails I get them across all devices, but sending them I can only access them from the device I sent from. I'm pretty confident up untill recently this wasn't the case.
Also recently outlook appears to be favouring searching emails from 2015-2014 (yeah I know I should probably just delete old ones)
Any idea what the issue could be? Or know what settins I should be running?
email address is an old blueyonder one.
If you have IMAP set up properly on all 3 devices then you should have access to all the same mailboxes for the simple reason that the mailboxes will be stored on server and not be on your actual device.
I have found that whilst VM will sync all incoming email across your folders it doesn't sync any sent emails. So an email sent on one device doesn't appear on any other device.
How about bcc'ing yourself automatically on all sent mails, I have found at work+home
this also helps with respect to searching/reviewing threads
