Embedded XSLT
11 Feb 2004
Surrey, UK
I'm hoping someone can help me create XSLT and embed it into the following XML file. It's a big ask I know. I've not succeeded so far and I'm wondering if it's because the XML uses the MS Office schema.
Code:
<?xml version="1.0" encoding="UTF-8"?>
<ss:Workbook xmlns:ss="urn:schemas-microsoft-com:office:spreadsheet">
<ss:Styles/>
<ss:Worksheet ss:Name="Information">
<ss:Table>
<ss:Row>
<ss:Cell>
<ss:Data ss:Type="String">Column Heading 1</ss:Data>
</ss:Cell>
<ss:Cell>
<ss:Data ss:Type="String">Column Heading 2</ss:Data>
</ss:Cell>
<ss:Cell>
<ss:Data ss:Type="String">Column Heading 3</ss:Data>
</ss:Cell>
</ss:Row>
<ss:Row>
<ss:Cell>
<ss:Data ss:Type="String">Column Data Row 1</ss:Data>
</ss:Cell>
<ss:Cell>
<ss:Data ss:Type="String">Column Data Row 2</ss:Data>
</ss:Cell>
<ss:Cell>
<ss:Data ss:Type="String">Column Data Row 3</ss:Data>
</ss:Cell>
</ss:Row>
</ss:Table>
</ss:Worksheet>
</ss:Workbook>
Hi mate,
XSLT is not something i work with very often but this might help you get started. Your request was a little vague so let me know if this is not what you are looking for.
Code:
<xsl:stylesheet version="1.0" xmlns:ss="urn:schemas-microsoft-com:office:spreadsheet" xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
<xsl:template match="/">
  <html>
  <body>
    <table border="1">
      <tr>
      <xsl:for-each select="/ss:Workbook/ss:Worksheet/ss:Table/ss:Row[1]/ss:Cell">
        <th><xsl:value-of select="ss:Data"/></th>
      </xsl:for-each>
      </tr>
      <xsl:for-each select="/ss:Workbook/ss:Worksheet/ss:Table/ss:Row[2]/ss:Cell">
      <tr>
        <td><xsl:value-of select="ss:Data"/></td>
      </tr>
      </xsl:for-each>
    </table>
  </body>
  </html>
</xsl:template>
</xsl:stylesheet>
Hi Andy,
Been on hols but damn happy to see a reply to this thread!
Basically I need to transform the XML into CSV using XSLT so the information can be fed into an application which excepts XML but only when XSLT is used.
The XSLT would be separate from the original XML as opposed to inline.
I'll try your sample out and get back to you - cheers! :)
Domo
This should help clear things up and describes exactly what it is I've been trying to achieve.
XML:
Code:
<ss:Styles/>
<ss:Table>
<ss:Row>
<ss:Cell>
<ss:Data ss:Type="String">Make</ss:Data>
</ss:Cell>
<ss:Cell>
<ss:Data ss:Type="String">Model</ss:Data>
</ss:Cell>
<ss:Cell>
<ss:Data ss:Type="String">Colour</ss:Data>
</ss:Cell>
</ss:Row>
<ss:Row>
<ss:Cell>
<ss:Data ss:Type="String">Ford</ss:Data>
</ss:Cell>
<ss:Cell>
<ss:Data ss:Type="String">Focus</ss:Data>
</ss:Cell>
<ss:Cell>
<ss:Data ss:Type="String">Green</ss:Data>
</ss:Cell>
</ss:Row>
<ss:Row>
<ss:Cell>
<ss:Data ss:Type="String">Volkswagen</ss:Data>
</ss:Cell>
<ss:Cell>
<ss:Data ss:Type="String">Golf</ss:Data>
</ss:Cell>
<ss:Cell>
<ss:Data ss:Type="String">Black</ss:Data>
</ss:Cell>
</ss:Row>
</ss:Table>
</ss:Worksheet>
</ss:Workbook>
The output should look like:
Make,Model,Colour
Ford,Focus,Green
Volkswagen,Golf,Black
By all means message me if needed. :)
That would be ideal - but the answer is no because it's for an automated feed from a cloud db into a locally hosted application.
The cloud produces the XML file which the app cannot read - hence the requirement for XSLT to perform the necessary transformation since the app can read in CSV.
VBScript it to save the workbook as CSV? Schedule task to run a bat file looking for the file in a dir and delete the file afterwards?
Try this:
Code:
	<xsl:output method="text" indent="no"/>
		<xsl:for-each select="/ss:Workbook/ss:Worksheet/ss:Table/ss:Row">
			<xsl:variable name="row" select="position()"/>
			<xsl:call-template name="processRow">
				<xsl:with-param name="row"/>
			</xsl:call-template>
		</xsl:for-each>
	</xsl:template>
	<xsl:template match="/ss:Row" name="processRow">
		<xsl:param name="rowId"/>
		<xsl:for-each select="ss:Cell">
			<xsl:choose>
				<xsl:when test="position()=last()">
					<xsl:text>
</xsl:text>
				</xsl:when>
				<xsl:otherwise>,</xsl:otherwise>
			</xsl:choose>
		</xsl:for-each>
	</xsl:template>
</xsl:stylesheet>
I'm just using character 10 for newlines rather than the windows CR-LF sequence.
I'm sure there's a cleaner way with just template matching on rows that doesn't need the explicit for-each-row in the outer template, but my XSL-foo is failing me at the moment.
