- 14 Mar 2011
Hey all,
I'm in the process of moving into a new house, and I'm sure we can all identify with the usual fear of unpacking all the PC bits and setting things back up, hoping that the bumps and shaking in the journey haven't caused any damage...
Well unfortunately my very old (7 years maybe?) Samsung 226BW (long live 16:10 1680x1050!!!) which has been making some high pitched noises for a little while has finally been killed off
I'm starting to get withdrawl symptoms here so I need a new monitor (or monitors
) ordered by the end of today. I've been looking through all the threads on here and reading reviews and I'm very confused. Few details of my setup:
- I had the Samsung + a Dell 1280x1024 as a little secondary monitor
- I want to keep a 2 monitor setup, it's just too handy having a second display while gaming on the primary one
- Graphics card is a GTX 670 and I can't afford to replace that too
- Primarily used for Gaming but also programming, music/video editing and 3d modelling
- Budget of probably £400-ish
Option #1: Replace the Samsung with a single very decent monitor (maybe the Acer 27" 144Hz G-Sync?) and keep the little Dell as a secondary. I'm worried the Dell might be completely swamped next to a larger monitor though
Option #2: Buy a pair of decent 24" monitors to replace the others completely. 2 identical ones would look good but it seems a waste to use 2 decent ones when only one will actually see any gaming action, so I could also buy a good primary and a less good secondary
Option #3: Superwide? I like the look of the 34" LG but no way can I stretch to that, and I can't decide if the cheaper 29" models are too short in the vertical. Did see a nice post where someone had 2 of the 29" LG stacked vertically which looked very good
What do you guys think? So much choice
TL;DR My old crap Sammy monitor has gone bust, need a new dual-screen setup, budget around £400 please
