- 18 Oct 2002
- Chesterfield
Presuming you have ABS:
I've often heard the best way to stop is, "•press as hard as you can on the brake pedal and keep full pressure applied until you come to a stop."
But.... the most friction is gained on stationary surfaces (ie not skidding).
and there has to be a skid (however small) for ABS to kick in, right?
So surely the quickest way to stop is to break as hard as possible without ABS kicking in?
As a complication to that, I guess the rear wheels could be causing the ABS to come on in which case it would be best to keep pressing as hard as possible? Can you detect the difference in ABS working on the front / rear?
Thoughts?
Thoughts?
