Hi Everyone,
Hope someone can help. I have a Gigabyte GA-Z68XP-UD3 mobo and I have been running a RAID5 with 3 disks. The disks were a bit old and only 3Gb transfer speed. I've upgraded the disks to newer models which support 6gb transfer.
I have enabled Sata3 in the BIOS and all the disks are plugged into the Sata 3 ports however the Intel Raid Utility is still showing that they are connected under 3Gb/s
Is there anything else I need to enable?
Thanks
A
Thanks
A
