Enabling Mod_rewrite
26 Jun 2003
North West
Im trying to do this.
Ive found sites that tell you how to enable it.
Inside the httpd.conf file uncomment the line LoadModule rewrite_module modules/mod_rewrite.so (remove the pound '#' sign from in front of the line)
I did this but the next thing to do was this
Also find the line ClearModuleList is uncommented then find and make sure that the line AddModule mod_rewrite.c is not commented out.
The ClearModuleList and AddModule lines are no where to be found in the conf file.
Im using xammp btw.
What am i doing wrong?
Thx
Im using xammp btw.
Thx
Exact same problem that, Google XAMMP and modwrite and you will see that a lot of people have the same problem.
There are supposed to be lots of solutions, but i googled for an hour and couldn't find one solution that worked.
If you do find a solution, give me a shout: ruudbarron [at] hotmail [dot] com
Hope it helps.
