Hi All,
I have been looking at upgrading to an SSD for some time and have now decided to go ahead with the upgrade.
The last thing I am looking into is enabling TRIM so that the drive works correctly and I am finding mixed messages across the internet.
I have found some stories indicating people have run into issues and the drive becoming very slow over time.
Whilst other articles have said you simply have to download and install some software called "TRIM enabler" and set it to "On".
What would you say the situation is? Is it as easy as just downloading and running trim enabler? Or are there other considerations/risks?
Thanks
Thanks
