encryption problem
26 Feb 2003
I've been backing up my work data to 2 external HDs, both of which are encrypted using the same key. I also backed up my key on both HDs to prevent loss of the key.
Now, when I plug the external HDs into my pc the data won't decrypt. If I import the key I put on the HD;s at the time of encryption it still won't decrypt the data! The password to import the key obviously works fine to allow me to import and install it.
If I just pick a file in my documents on the pc I can encrypt/decrypt it perfectly. So no problems there, it's just I can't recover the data on external hd's using the key stored with the data (this is all uncer xp pro)
Also, I haven't changed my login username/password at all
Any ideas what is going on here cheers??????
