Encryption with USB stick instead of password?
4 May 2011
A fairly straightforward question hopefully, but is there such a thing as hard drive encryption software that uses a USB stick instead of a password? e.g, I go to my PC, plug in USB, turn it on and it boots into the OS without further prompts, but without USB, won't boot at all.
Because of a use case where physical security is trusted more than information security if you must know (Someone always asks)
Bitlocker can do this. You need windows 7 ultimate or windows 8 pro though.
Bitlocker you can use:
tpm (chip on motherboard), pin (startup password), startup key (usb memory stick)
