Ender 3 V2 Neo Sprite Pro Extruder
28 Oct 2002
Somewhere, maybe nowhere
Hi, just in the process of waiting for delivery of a Sprite Pro extruder kit for my Ender 3 V2 Neo, I know it needs some modification to the x-axis end stop, but I am also running klipper firmware from a pi primarly with Fludd and Mainsail.
I was just wondering if anyone here has any guidance for the printer config file to get the sprite working so I can calibrate pressure advance etc? Just trying to get a head start before it arrives.
I'd say look up the klipper setting for sprite and it should be easy.
Will do, was hoping someone would have had some experience, but I guess I will post my progress here just I case anyone else does the same.
Hi
i got "non v2" neo with sprite extruder SE.
Its just the extruder without the hot end. You will definitely have to change the rotation_distance.
THey say its 424.9 Esteps so that going to be 7.53.
that all i had to do to get it working.
Since you are changing the whole thing just find a config for a printer that has that type of the extruder and copy [extruder] section
I calibrated pressure advance with a guide from klipper website with the square tower print.
This is my Printer.cfg extruder entry - Don't take it as gospel as I'm always tinkering so some things might be a little off - the latest one that I'm working around is that I've replaced the 42-34 motor with one of the bigger steppers and it collides with the Y bed bracket so I currently have a modified Y endstop and a slightly smaller print area. When I can be bothered I'll trim off a little from the Y bracket.
[extruder]
max_extrude_only_distance: 100.0
step_pin: PB4
dir_pin: PB3
enable_pin: !PC3
microsteps: 16
rotation_distance: 7.4547
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: PA1
sensor_type: EPCOS 100K B57560G104F
sensor_pin: PC5
#control: pid
# tuned for stock hardware with 200 degree Celsius target
#pid_Kp: 21.527
#pid_Ki: 1.063
#pid_Kd: 108.982
min_extrude_temp: 170
min_temp: 0
max_temp: 300
Pressure_advance: 0.06
max_extrude_cross_section: 5 # For KAMP purge
This is my BLTouch:
[bltouch]
sensor_pin: ^PB1
control_pin: PB0
x_offset: -31
y_offset: -42
#z_offset: 0
speed: 35
samples: 2
samples_result: median
samples_tolerance: 0.0075
samples_tolerance_retries: 10
probe_with_touch_mode: true
stow_on_each_sample: false
sample_retract_dist: 8.0
