- 6 Oct 2018
- Isleworth
I have started seeinf this new issue which has rendered the printer as inoperative.
The problem appears to be on the x axis with the hot end assembly shaking and vibrating
as if the belt is slipping.
I truned off the machne and have chhecked all the belts and movement of the hot end assembly
and cannot find any issues.
Appreciate some advice on how to fix this issue.
Nelow is a link to the video showing the problem which starts at 1:33
