I just purchased a Enermax Galaxy 850w PSU and i've run into a bit of a problem.. it won't fit in my Antec P180! There is a support bar about half way along the bottom compartment where the PSU goes and there is no chance of even getting the PSU in the space there. Worst still the support seems to be held in place by rivets.
So a couple of questions.
1) Does anyone have the EGA850EWL inside an Antec P180, and if so, how!?! (I'm going to guess some drilling/cutting/dremel'ing is involved)
2) My new system will be a dual 8800GTX and QX6700 with a number of HD's thrown in. Can anyone suggest a suitable replacement for the EGA850EWL that fits in the P180?
3) It's quite feasible that I will just leave my current system in the P180 (was going to be moved to old Cooler Master ATC200) and just buy a new case for my new system. Can anyone suggest a cool, quiet case? (Budget around the £150 mark preferably).
Cheers all. Answers on a post card to any address you fancy.
