Hello,
I have had this enermax Galaxy 1000w PSU for around 8 years.
1 month out of warranty the bottom fan (1 of 2 fans inside the PSU) decided to die.
I was left with a PSU that wouldn't boot. So i tried taking the bottom fan out, still wouldn't boot. So I found a 135mm fan that had 120mm mountings and bodged it together.
The PSU works fine however... every so often it will beep 3 times indicating a fan warning. Then just carry on. rarely happens, so im fine with it.
After installing a new motherboard and cpu the beeping has come back worse than ever!
It's beeping every 10 seconds and sometimes takes a 10minute rest.
I would like to know if there is any software that can change the speed of the fan, as i feel that an rpm drop of this fan is causing the beeping.
Or if anyone knows how to fix this please let me know. And in worst case, link me to a decent PSU
