I can't find any info about the compatability between these two, does anyone here have the same setup? I have removed one of the PSU cages to fit my 480 neopower in, but I have no idea if the galaxy will fit :E
Not sure as I can't measure it at the moment but I think you might have to remove the divider wall between the PSU bay and the hard drive bays. Not a problem as the divider is held in with screws rather than welded. I had to do the same thing for my PSU as it was modular and the divider has a hole through it which is designed for fixed cable PSUs.
