Enermax Galaxy 850w Cold Boot Problem
7 Dec 2006
Hi ya peep
Just wonder if any of you could give me some advice on this problem
I’ve got a bit of a head scratcher with my new rig
The system is having major problems on first boots
System restarts fine once warm
And has no crashing problems or power failures problems
Problem:
Every time I try to cold start the system
The Enermax galaxy PSU (Starts then Stops) normally 2 or 3x
Then dose 2 bleeps continually till the reset is pushed on the PSU
You then have to turn the power switch of till the light goes green and
Run through the same procedure till the system starts
Once started its perfect
I sent the first PSU back as faulty and was swapped without any problems
But the second PSU is doing the same thing
I’ve done a minimal hardware boot
I.e. just GFX, RAM, CPU and it still does it
My old Enermax Liberty 620W runs the system fine
I’m just hoping it’s not another bad PSU in a row
Any ideas would be welcome
Cheers Encoder
PC SPEC:
AMD Athlon 64 X2 Dual Core FX 62 2.80GHz (Socket AM2)
Asus M2N32 WS Pro nForce 590 SLi (Socket AM2)
Corsair 2GB DDR2 XMS2-6400C4 TwinX 800MHz, CAS 4-4-4-12,1.8-2.2v
2x BFG GeForce 8800 GTX 768MB GDDR3 HDTV/Dual DVI (SLI ready)
Enermax Galaxy 850W EGA850EWL ATX2.2 Modular PSU
2x Western Digital 120gb harddrives
Pioneer DVR-111BK 16x16 DVD±RW
