Enermax galaxy in Akasa Eclipse 62?
30 Jul 2006
Leeds Booo..
Sorry for this post but my internet is acting up and can't seem to load up any or all pictures!!. Just wanted to know if the Eclipse has enough room for this PSU and doesn't hang off the edge of the support and whether it would take the weight. Cheers, just seen this on offer of the week and want to order instead of the Tagan 800W.
370mm max length
250mm to end of shelf
200mm wide
That enough space for ya? lol
the shelf is 1.2mm thick and is pressed to give it even more strength so will hold loads of weight.
HTH
Its a bit late but the only preview of this PSU on the net was using a Savrow SR71 (eclipse).
850w PSU in it should fit as said, as they mentioned nothing negative about it, will have to make sure you let me know how these PSUs perform as they are quite tempting.
I'll let you know when I've built it but it's a few weeks yet till I can get all my parts together. I bought this now cos it was on offer. I didn't know the eclipse was referenced under Savrow SR71 or Global Win YCC-61F1 as I just found out through google. Was wondering why I couldn't find much info on it. Cheers for that Yewen. :)
