The Tagan TG480-U01 is a PSU I've been familiar with ever since I reviewed it for ***** over a year ago. Since then I've used the review sample in my main testing system and I have my own bought unit in my personal PC. It's been through a number of minor revisions since its introduction, to add and tidy up the available connectors and do away with the EATX-to-ATX converter. The latest revision with 2 PEG connectors was tested. It passed the full-load tests without issue, voltages were solid if a little low under full load and efficiency was acceptable, if in the middle of the pack overall. Connectivity is the Tagan's strong point, the latest revision able to power just about anything, including a pair of PCI Express graphics boards
All loops are braided from nearly the source, to the endpoints of each cable run and its appearance is one of quality. Didn't miss a beat, but is bested in the graphs in all areas, if only by tiny margins in many cases. I won't be switching to anything else because of it, though, which hopefully says a lot.
Recommended system: Mid-range to high-end desktop systems based around P4 (including high-speed Prescott), AMD Athlon Socket A and AMD Athlon 64 and Sempron on Socket 754 and Socket 939. Server systems due to SSI connector. SLI-ready out of the box with the latest revision.
