Enermax Librty PSU Buzzing?
20 Jul 2006
Had an Enermax Liberty 500W for 4 months now, Swapped fan with 1200RPM Scythe when bought, but just started to notice buzzing noise from it, voltages are fine and with fan unplugged still get buzzing noise, so maybe one of the coils/capacitors?, is the PSU dying?, should I be worried?, is there an explanation?
Using in a P182 case, so the fan in PSU is pretty much used to cool it down and the warm air in the case is exhausted by other fans...
