Hiya guys n girls.
Firstly my apologies... for those reading this, its probably simple, for me, im not as young as I was lol, things have changed, its been 5 yrs since my last build and I just want to get it right with no mistakes
Ok I need to know about all the different plugs on this damm PSU!
ENERMAX REVOLUTION 1050W
1) Please look at the photo below..... this is the P5Q MoBo from Asus, top left there is a white plug, but part of it has a black bung in it.. to the foreground and left a little is the plug im assuming goes into the Mobo.
Now do I remove the black bung to allow fitting, why is it bunged in the first place lol currently i dont have a plug that fits im sure
2) The GFX Card in the Tower is a Sapphire 4870 x2 and there are two sockets for power (I ASSUME you need to have BOTH in use?? as the manual that comes with this card has NO explaination of what the power requirements are or what your suppose to plug into it!)
Now, there are two leads again that come with the GFX card (These are on the LEFT of the picture) but also there are leads that come with the PSU and also the PSU itself has these connectors (These are on the RIGHT of the pictures) but im a little confused as the ones on the PSU (Also the extension cables) have 6 pin and then a two pin. am I right in assuming that
A) you need to have BOTH sockets powered
and that
B) you use the 6pin+2pin as an 8 pin plug?
Lastly the PSU as I said comes with the main Mobo 12 pin connector, the ones above I assume that you use for the GFX card, and a comple of others, but there are LOADS of plug in cables to that plug directly into the PSU
Is it better to use the additional plug in ones, or if they are there and exist (GFX CARD power plugs for instance) use the ones that are hard wired into the PSU?
Very confusing for a total noobie lol so please be gentle with me! I only want to learn
Chris
and that
Chris
