Right, i'm stumped.
Put the engine in, went to turn it over, one click and nothing. checked the battery, fine.
Starter I think, So I turn the crank bolt to free it. It turns a bit the makes some metallic banging noise. At this point I'm worried. I instantly think cam timing, but I made sure that was right when I put the belt on, Ie turned it over about 10 times by hand, all was fine.
So that should also eliminate seizure. So I go back to the starter, I take it out and try and turn with the crank bolt, wont budge, I can move it about 5 degrees each way.. odd.
So it's not the starter. not the timing and not the battery. Err what else can it be.
Thinking back though after I put the gearbox on i could no longer turn the engine via the crank bolt after that, I thought the box was in gear though so didn't think anything of it!
As i understand it, if the clutch components aren't aligned the box won't go on, so that must be fine (did it by eye). But is it possible I've put the clutch plates on the wrong way or something? I also can't get it in reverse, I've not messed with the linkage, just took it off and on (box end)
I can't even push the car back in neutral or anything, it's just like something is physically stopping it! Any of this make sense?
thanks.
thanks.
