Went with a mate to have a look at a 2001 A4 1.8T earlier this evening.
Dealer says that the car has a fault with the engine. Basically there's an intermittent knocking / rattling / tappety noise coming from the engine. It definitely doesn't sound healthy when the knocking comes on. It sounds like something hitting something internally that it shouldn't be.
The dealer says it could be the oil pump or pressure valve and does not recommend driving it for any great distance in case the pump fails.
If its historically had an oil pump failure, presumably this would cause the engine damage. If so, can these engines rebuilt, and if so, at what cost? What the likely cost of a recon'd replacement 1.8T engine?
In a best case, and worse case scenario, what could it be and how much could it cost to get it fixed?
