So, it's an SR20DET and the issue is the temp goes up when you give it the beans. No problem at all idling.
This has to be a blocked radiator or a jammed thermostat right......
The rad should be ok, it's an enormous alloy one which seems fairly new.
I'd say it's more likely to be the stat, even though they usually stick in the open position. I think my first port of call will be to remove the stat and take it for a thrash to see if it helps.
What do you guys think? What is the best way to clean out the radiator?
Oh, already tried changing the rad cap, made no difference.
