I'm currently in the process of re-building the engine on my bike. I know you guys mostly specialize in car mechanicals, but I think this'll be the same answer for cars and bikes.
The generator on my collapsed a few months ago (the resin disintegrated) and having that much mass spinning unevenly has caused a couple of the pistons to crack. Obviously the generator and cracked pistons need replacing, but...
1) Will all the pistons need changing to have a matching set or just the dead ones?
2) Can I re-use the old piston rings
3) Will there be anything else (bearings etc) that should be replaced when doing this?
Response is appreciated, you'll get a decent "rebuilt from scratch" project thread if I can sort out the engine
