- 19 Dec 2010
- The south
Okay, so I bought an A3 on friday, after having a run around in it, and the temperature was rising fine when I test drove it. Admittedly I wasn't in it long enough for it to rise all the way, but it was on its way so I presumed all was fine.
On the way home, instead of sitting at 90 degrees, it stuck at 70. I can't remember if that was with the AC on or not.
Ive been keeping an eye on it all weekend, and I can't suss it out. The temperature rises to 90 after a while, but it seems to pause at 70ish, this is with the AC not on.
I had noticed the fans came on when I started it up at one point.
Initially I thought the thermostat was broken, but I'm not sure?
Any thoughts?
Any thoughts?
