*Inserts obligatory 'I don't know anything about cars' disclaimer.*
I have noticed with my Audi A4 2010 (Diesel Automatic, if it makes any difference) takes a few seconds longer to start recently. It's only used on the weekends and so it usually goes 5 days without use and I've noticed on that initial startup, it (the engine) takes much longer than usual to turn on.
One potential correlation I have spotted is on the initial startup after those 5 days have passed, the fuel tank is almost empty (i.e. because my weekend driving resulted in me using most of the fuel). I have also noticed it has been a lot colder recently; I am wondering if this could be affecting it? Or even if these two things might be interacting with each other, resulting in the delay?
What's prompted this post is I went to move the car today which hasn't been driven since Saturday and it took particularly long for the engine to finish turning over (I'd say about 3 seconds, which is much longer than usual).
Could something be on the way out or is this normal given the weather and nearly empty fuel tank? A quick Google tells me to investigate fuel pumps, glow plugs and batteries but before I go wild I thought I would check with you knowledgeable people in case I am insane and this is normal.
