Is there a reliable general calculation I can use to work out the effective reduction in SWL of an eye bolt, when loads are acting at any angle other than 90 deg. to the bolts axis? Got 4 off M36 eyebolts with an SWL of 6.3T each being used for the lifting of a 10T load. The sling angles are pretty hellish-looking, and I've a feeling that M36 isn't enough.
Also, am I right in saying that one bolt must be omitted from the loading calcs, as effectively only 3 do the work (with the 4th only balancing the load)? This is obviously assuming a 4 point lifting system.
Cheers!
Cheers!
