I need to rotate a large Diameter ring say 15 degrees with a worm gear. Obviously don't need have teeth all the way around the ring so I'm attaching a curved rack of 20 degree range. I want 60:1 ratio but here lies the question:
Do I take no. of teeth - 60 - across the entire ring (ie. 2.5 teeth across the 20 degrees) or just the 15 degrees I need?
Pleeeeease help! I can't find any relevent theory anywhere for this!
Cheers
Chris
Cheers
Chris
