- 15 Mar 2004
- Oxford
Hello,
I need some help by some clever people.
I am looking to adapt a sump for my Freshwater Fish Tank.
I need to know how much water would flow through a 5mm hole, so i can work out how many i need to drill in some perspex to let enough water flow through. Potentially upto 12,000ltrs per hour.
The red lines represent the perspex. Sheet 1 will be drilled below the blue line. Sheet 2 above it.
The green is the flow of water, and i'll have a pump in the last chamber to send it back up to the tank.
I can't leave a gap under, or above the perspex as the middle will be filled with plastic things moving around and the idea is the keep them in that compartment.
Essentially how much water would a 5mm hole let through. There will be no lid on this so no real forces at play apart from mavity.
I did try googling but i can't find an answer
good luck.
