Hi
When I first start my bike I get a rattling sound that lasts for a few minutes. After that you can't hear it at all. If the bike is left switched for over 15 minutes you will slightly hear the rattle on startup but like I said worst case which is when the bike has been left overnight the rattle lasts for a few minutes.
It doesn't change if I dip the clutch. It sounds like it is from outside the engine rather than inside it.
Any ideas on what it could be?
My bike is a 51 Yamaha Thundercat that has done 24k miles.
