Enhancing application fsaa settings..
Suspended
18 Oct 2002
Ireland
Usually something i don't bother with as i normally just stick to ingame settings. Was going to try 32x for a laugh but it seems the control panel wants to disable multigpu mode to do this:
Wonder why it would want to do this as performance on a single gpu would be pretty bad to say the least. Or is it disabling one gpu from game performance to handle the anti aliasing setting? :confused:
The 200 series doesn't natively support 32x AA - it needs to use both cards to do 32x AA (simple, not entirely correct, explanation: effectively doing 16x coverage on each GPU - the max supported - and then combinging the output) you don't get the same performance hit as doing 32x AA on one GPU but it won't give the greatest performance either.
I seen a review a while back showing 64xaa available on a 295 sli setup, apparently done via a registry entry.
AFAIK proper 64x AA is only available on the 200 series with Quad SLI but I could be wrong.
tri-SLI 400 series cards can do 96x AA lol.
