Enough juice?
12 May 2005
Will a corsair HX520W be enough for a Q6600 @ 3GHZ, 4GB of ram, and a GTX570?
I'm planning to switch the Q6600 for a sandy bridge in jan, which from my tiny bit of research, seems to require less juice as well?
This is with 2 sata drives, a couple of fans (4) and a DVD writer which is hardly ever plugged in. :p
*EDIT* currently running a Radeon 4850
What about the 6950? I assume a 520 watt PSU you would be okay with that, I'm torn between a 480 and a 6950 at the moment so looking at reviews between the 2 :p
http://www.guru3d.com/article/geforce-gtx-570-review/8
Core i7 965 / X58 system
Measured power consumption
1. System in IDLE = 181W
2. System Wattage with GPU in FULL Stress = 369W
3. Difference (GPU load) = 188W
4. Add average IDLE wattage ~ 25W
5. Subjective obtained GPU power consumption = ~ 213 Watts
GeForce GTX 570
* On your average system the card requires you to have a 600 Watt power supply unit.
GeForce GTX 570 in SLI
* A second card requires you to add another 225 Watts. You need a 850+ Watt power supply unit if you use it in a high-end system (1 KiloWatt recommended if you plan on any overclocking).
