enough power (gtx 295)?
OCUK will make sure the PSU they provide can power that card, so you should be fine there.
Why don't you build it yourself? You can pick and choose what you want in it and generally for much cheaper. Give us a budget and requirements and we can spec up a PC for you.
The above is an example of what you can put together yourself. I've put a 4870x2 in instead of a 295 as I feel it offers better value for money than the nvidia, while offering similar performance. What resolution are you playing at?
I noticed the ultima excalibur gives 12gb of DDR3 ram, which unless you plan on doing a lot of heavy encoding or any other software requiring a lot of ram, then 6 will be more than enough for most, especially in games.
I've shown the oem version of the i7 CPU (doesnt include the stock cooler) and included an aftermarket cooler instead, which will get a pretty decent overclock from the 920.
well i am put off building my own pc in case i do something wrong, is it difficult to do? i've only done simple things like replacing ram and stuff like that before. i have £2,300 to spend but that includes mouse keyboard and monitor.
The wattage would be fine, the 12v is 25A x2, Max 42A combined, which is just on the safe limit for that setup, so it should be ok.
I'm sure OC know what they are doing and would probably upgrade the PSU if it wasn't up to the job.
