Man of Honour
- 8 Nov 2007
- Outer Space
Hey guys,
Putting together another water cooled PC and just wanted to check if it'll be running with enough radiator capacity?
CPU - Intel Core Ultra 7 265K
GPU - AMD Radeon 6950 XT
Radiators:
1 x 360mm x 44mm
2 x 240mm X 44mm
Will it need any more as I know the AMD 6950 XT runs very hot and I'm toying with the idea to change the 2 x 240mm rads to 360mm's?
Thanks
Radiators:
1 x 360mm x 44mm
2 x 240mm X 44mm
Thanks
