So guys I just brought this: https://www.overclockers.co.uk/showproduct.php?prodid=FS-101-OE
With the GTX 460 768MB graphics card option, though now I feel a bit silly because I've been told & read that soon there'll be games that will easily fill up a 1GB graphics card and I don't even have that, so I was maybe gonna buy another GTX 460 768MB or just bung a GTX 470 1GB in there too.
Thing is I'm a massive hardware noob and can't tell if there's enough room in there. Looked inside the beast and it doesn't really look like it'd fit.
I put a network card in the PCI slot available and underneath that there's a slot that looks similar to the one the graphics card is in although there's other wires & stuff in there that would prevent a graphics card fitting in there.
Well enough waffling on I was just wondering if anyone knew if there was enough room to slot another graphics card in there or will I just need to plump for a whole new 1.5GB~ graphics card?
. Save up for the new AMD 69xx cards for a decent upgrade in future, or whatever Nvidia bring to the table. 2x 460s will not solve any memory limitations you may run into, as it's still 768MB per GPU - you dont double your VRAM with SLI! Will get a decent performance gain though (dunno what hybrid572 is talking about really - 2x 460 spank a single 480 in games that support SLI well, which is pretty much all of them nowadays).
(but what doesn't
