Enough wattage?
27 Jul 2007
Hi all,
I have a PC/server at the moment that runs the following hardware:
Supermicro X8SIL-F motherboard
Intel Xeon X3450 CPU (i5-750 equivalent?)
16GB RAM
ATI HD6450 gfx
2 x SATA cards
Crucial M4 256GB SSD
14 x 2 TB drives
The PC currently has a Corsair HX520 PSU, which has worked flawlessly for 3 years. I'm thinking about moving the PC from the lounge to my desk so that I can start using it for gaming. I've had a very, very long break from gaming in general, and I want to have a bash at the old classics like Half-Life 2 and Warcraft 3 and some newer less-demanding games like Starcraft 2, Diablo 3, new SimCity etc.
Do you think the PSU will cope with an ATI HD7850? It seems like the appropriate gfx card for me given the age of the games I want to play. Would a HD7950 be a step too far?
I have a Dell U2713HM so I'd like to play at 2560x1440 if I can.
Thanks :) Were you guys referring to the 7850 or the 7950?
The hard drives are set to spin down after ~20 min, so almost all of them are powered off most of the time.
Thanks :) I googled around a bit and they say that the difference between 8x and 16x is minimal at best.
Now I just have to decide whether to go for the 7850 or 7950. The 7850 is probably the more sensible option since a lot of the games I want to play are quite old.
Thanks :) I got worried that the card wouldn't fit after you mentioned it, but I just checked the PC and I my 16x HD6450 fits in the 8x slot, but half of the card hangs outside of the slot.
I think I'd rather have a second hand 7850 than go for a 77xx card. Thanks though!
Well I bought a second hand HD 7850 which is overclocked to 1170Mhz. From the screenshot below, does it look like my CPU is bottlenecking the graphics card? The card seems to only peak at 78% usage in Battlefield 4:
14x2tb HDD..inside the pc? I switched to putting my storage on external 2tb drives cos the pc was getting stupidly heavy and warm.
They were spun down most of the time :) I can't disagree with you about the weight though. My Fractal Design XL case is stupidly heavy.
But, all 14 drives will be sold soon. I'm downsizing to 2 x 4TB HDDs.
