The BRAS profile is responsible for regulating the maximum throughput (data rate) you will receive on your Max DSL service. Initially this is set to 2Mbps (if the line rate is above 2272kbps), but it will increase if your line can support higher speeds than this. The first data rate increase should take place within 75 minutes of your receiving Max service. Your BRAS profile however, changes only when a stable connection has been made for a period of time; this may be up to 3 days in some cases. The BRAS Profile will also drop should the line rate decrease significantly. See Blip Logic for more information.
