OcUK Staff
- 23 Feb 2015
- Overclockers UK HQ
Hi guys,
Save £15 on the CS:GO Hyper Beast skinned Rival 300 mouse by entering voucher code:
"BEAST15"
at the checkout! Offer ends 18/01/2017
SteelSeries Rival 300 Optical Gaming Mouse - CS:GO Hyper Beast Edition (62363) @ £69.95 inc VAT https://www.overclockers.co.uk/stee...s-go-hyper-beast-edition-62363-kb-084-st.html
The SteelSeries Rival 300 CS:GO Hyper Beast Edition is the ultimate professional-grade gaming mouse featuring an exclusive Hyper Beast design.
This mouse offers cutting-edge features including an optical sensor with zero acceleration, new long-lasting SteelSeries switches, and ideal ergonomics for enhanced comfort.
The ergonomic grip is accentuated by the injection molded rubber side grips and intuitive, ergonomic button placement. It can be customized through a host of features including response time, adjustable buttons, dual lighting zones, our ExactTech settings, and a 3D printable nameplate. The Rival 300 CS:GO Hyper Beast Edition is the perfect mouse for all Counter-Strike fans.
Unmatched Performance
Zero Hardware Acceleration - precise tracking at all speeds
Configurable resolution up to 6,500 CPI
1ms customizable response time – no lag
SteelSeries switches > 30 million clicks lifecycle
All New Grip and Design
Incredible design featuring the fan-favorite, "Hyper Beast" in-game skin
6 programmable buttons (incl. CPI)
Soft feel non-snag cable
Sweat resistant matte coating for long-lasting comfort
Large rubber grips for maximum comfort and lift
Shape based on iconic gaming mice of the past
Customization
Exact features – Aim, Accel, Snapping
16.8 million color, 2 zone illumination
User customizable 3D nameplate
Cloud sync’d profiles
Quickset actions stored onboard
Specification
Engine 3 support 1
Batteries Included No
Cable Length 2
Cable Length 6.5
Wireless No
Connector Type USB
Documentation Type Quick Start Guide
Sample of Documentation N/A
Number of Programmable Buttons 6
Scroll Wheel Yes
Number of Buttons 6
Frames per Second 6500
Inches per Second 200
G (acceleration) 50
Counts per Inch 5000
Lift Distance 2
Lift Distance 0.08
Ambidextrous No
DCPI 6500
Programmable Keys Yes
Illumination Yes
Profiles Available Yes
Macros Available Yes
Finish Matte
Firmware Upgradable Yes
Onboard Memory for Profile Saving Yes
Gold Plated Connector No
Switch Life-Cycle (Clicks) 30 million for left/right clicks, >1 million for others
Cable Material Rubber
Number of Illumination Colors RGB (16.8 million)
Number of Illumination Zones (zones per earcup for headsets) 2
Sensor Type Optical
Feet Material PTFE
Extended Cable Included No
Illumination Modes Steady, Pulse, ColorShift, Gamesense, off
Only £69.95 inc VAT.
ORDER NOW
"BEAST15"
Customization
Specification
Engine 3 support 1
Cable Length 2
Cable Length 6.5
Wireless No
Connector Type USB
Scroll Wheel Yes
Number of Buttons 6
G (acceleration) 50
Lift Distance 2
Lift Distance 0.08
Ambidextrous No
DCPI 6500
Illumination Yes
Finish Matte
Sensor Type Optical
Feet Material PTFE
ORDER NOW
