Hey,
I'm really having a problem deciding what way to have my loop. I don't want tubing all over the place and want it to be fairly clean. It's my first time watercooling so I'm struggling to work out the amount of fittings I will need.
I massively underestimated the amount of fittings I would need.
I currently have:
6x Monsoon 16/10 Straight - Chrome
2 x Monsoon 16/10 45 - Chrome
1 x Monsoon 90 - Chrome
That is the design I'm looking for. The pump will be on the other side in the bottom of the case, opposite to the monsta rad at the bottom.
480mm rad at the top
360 Monsta at the bottom
EK Res x3 250
Will be grateful for your help!
I currently have:
EK Res x3 250
