Yes I have
Can you clarify what you would likeHello guys, if someone owns this case, could you please measure space from last pci-e full space
I just need to know how high GPU's can fit in that slot my motherboard.
Basically i want to fit GPU for another OS in the bottom slot of my X570 Meg Ace, so could you please measure space from bottom slot up to any obstacle (i need around 6 cm for my GPU, as my p600s has PSU cover straight under my motherboard and i can fit only single slot GPu's)Can you clarify what you would like
Measured please
From the slot to the glass?
Or you mean if gpu is mounted vertical?
Happy to measure for you
Once I understand what you need
Sorry I must be having another oneBasically i want to fit GPU for another OS in the bottom slot of my X570 Meg Ace, so could you please measure space from bottom slot up to any obstacle (i need around 6 cm for my GPU, as my p600s has PSU cover straight under my motherboard and i can fit only single slot GPu's)
Thank you!
So basically how big GPU can be installed in the bottom PCI-e slot.Sorry I must be having another one
Of my DOH! days
But can't picture what obstacle
Would be above the slot?
Below it yes as you said the psu cover
Is there
But only thing above my bottom slot
Would be whatever is in my
Second pci~e slot
Sorry for being a bit thick
But bear with me I will get what you
Mean in the end if you keep explaining
So you mean how much space belowSo basically how big GPU can be installed in the bottom PCI-e slot.
Something like this, i guess PSU cover not gonna allow me to install bigger GPU.
https://prnt.sc/r9hqce
Sorry, didn't have time to say thank you! It's ok, connectors not that high, so i don't think that GPU mount will be a problemok i have 55mm
but i couldnt put a gpu in there anyway
as my usb ports headers and audio headers are in the way
only a thin card like usb expansions etc will fit there for me
