Enthoo Evolv ITX
27 Mar 2016
Bristolian living in Swindon
Hi all
Looking to Downsize my case to the Enthoo Evolv ITX... just wondered if anyone has this case that can share their thoughts...
Also will my motherboard and GPU definitely fit
H110M-K motherboard
1060 MSI afterburner single fan
Thanks
Its an ITX case and I think you have an MATX board, so no - you will need an ITX board. Your board will need the larger MATX case.
Damn :( will have to get a new motherboard to... not what I had planned but if it needs to be done then I'll have to :p more money spent
also, if you are actually looking to buy evolv itx, it's worth to wait for more news, as tempered glass version was recently showed (not sure about release date though).
I was wondering if they done the tempered glass version but I do like the smaller window one
Minibiker.. Not much in Dimension..
The Phantek ITX version Very large for a ITX case ,
You could go for a Corsair 400c that takes up to full ATX for around same Dimension OR the In win 101 case tempered glass quick rel , just come out.
Phanteks Case ITX Dimension: 230 mm x 375 mm x 395 mm (W x H x D )
Phanteks Case Micro ATX Dimension: 230 mm x 453 mm x 400 mm (W x H x D) Micro ATX version a little more in height ,Got a Quick rel Door
"IN WIN A1 itx Cube Case" is the Case to get when rel :)
