Enthoo Luxe question
30 Jan 2012
Hi guys, questions for anyone who has an Enthoo Luxe.
Are the bottom fans of any use if you keep the psu shroud and HDD bays in? Its not easy to tell that from the piccies I've seen.
Also, how is airflow to the GPU? I will be water cooling the CPU but won't have the funds to expand the loop to the GPU.
Thanks in advance.
Just built one of these..
So you wouldn't be able use bottom fans with a PSU shroud or drive bays. Removing the drive bay you maybe able to get a 120mm in. With some very clever cable management you maybe able to get another 120mm in next the PSU if you leave the shroud out.
Airflow is 200mm intake on the front, 1 x 140mm out on the back and I guess the top one can be in or out, you can certainly fit another 140mm at the top. I guessing airflow won't be an issue.
Thanks for the quick reply.
I really like the PSU shroud as it keeps the bottom of the window looking neat and worry that without it the look might be spoiled. I don't want to compromise the performance by reducing airflow though.
