Hello, just after a little advice from anyone whos filled one of these cases with rads. Im just in the process of adding another 240mm rad to the front right position and im wondering if anyone found which direction to put the fans for the best airflow.
At the moment i have the front 240 and bottom 360 drawing air in and the top 360 exhausting along with the rear 140 fan. Im thinking if i put the new 240 on the right also drawing air in might cause hot air to build up, i know positive pressure is good but im thinking of having one of the front 240s exhausting instead.
Normally i would just test both and see which is best, but once i get it piped up i will have to remove all the pipes and pump to get back to the fans, so i thought it would be a good idea to see if anyone has tried this (or something similar) already and could save me a lot of hassle.
Cheers.
Cheers.
