Enthoo Primo Watercooling build
Nice one! Love that yellow.
I came *this* close to buying an Enthoo over the last few days, but decided to buy toys instead :D You, Colin and Scotty do have me feeling a little jelly though :)
Thanks for the comments, and thanks again to Petey for the help pre build.
The side window of the Phantek's is tinted so I can barely see my work, so I've ordered a white LED. I'm also pondering about switching the fans out for some Corsair ones but I think that's a bit pointless.
Well it's been over a week now and no leaks and temps as good as ever. Was a pretty expensive thing to do but I couldn't be happier with the results.
Hey Chris, great build! Just out of interest, are you planning on selling either of your old air coolers from the 2 cards? I have a ref sapphire 290p that's driving me nuts but don't have the funds to watercool it right now.
I think you should spray the fans yellow. Looks amazing tho
That's too much modding for my liking, I like to keep things simple.
I'm keeping them in case I need to RMA one of the cards.
Do they work well with rads? And what's the noise like?
I have never used GT's so don't know what the vipers are like for comparison but would recommend them to anyone. I used them on my WC build and was very happy with them though at full pelt (1900rpm off the top of my head) they is a lot of wind noise and a little motor noise, but running 800-1000rpm they are silent.
I thought I had a couple lying around from selling my build but unfortunately the only one I can find at the moment is one I painted blue. While the blue wont go with your build I am happy to post it to you so you can compare it to the GT's.
Do they have braided cables? Don't worry about sending me anything, it'll be a long time before I actually go for some new fans. I'm thinking about getting another 290X in there which will need some work, just unsure if the two rads will be enough. :)
The cables are braided up to the body of the fan. No problem, offer is there if you ever want it. I would have thought you could run another gpu in the loop without issue, if you work on 120 per component you have 360 for good temps. Thought I don't know what sort of heat the 290s produce.
Came home, noticed temps a little high and fluid had dropped slightly. Brought the case out (it's fairly large!) to have a look. :(
Just what I need on a Monday evening.
Looks to be the bottom GPU block. It's right where the seal is between the block and the terminal.
I don't really know what to do now, just sat here in disbelief. I'd have to strip it all down which means losing most of the water as I didn't bother putting in a drain as parts hadn't arrived. I figured I'd sort that in 6 months. :(
Hate to say it but probably will have to strip it out and re-install everything, sucks but if the block needs re seating or summit no other way? : (
This is one of the reasons i sold my watercooling my motherboard got rma'd and i was so ****ed off i sold it all! Also helps with servicing and changing out any components in the future.
