Hi all, This is my first build (put together by someone on the forums) thought I'd make this as I'm open to helpful advice in case I come across any difficulties along the way Which I most likely will!
YOUR BASKET
1 x EVGA SuperNova G2 850W '80 Plus Gold' Modular Power Supply £95.99
1 x Phanteks Enthoo Pro Mid Tower Enthusiast Case with Window £89.99
1 x Corsair Hydro H105 Extreme Performance Liquid CPU Cooler (CW-9060016-WW ) £89.99
1 x Asus P8Z77-V LX Intel Z77 (Socket 1155) DDR3 Motherboard £85.99
1 x Kingston HyperX Predator 8GB (2x4GB) PC3-19200C11 2400MHz Dual Channel Memory Kit (KHX24C11T2K2/8X) £65.99
1 x Crucial MX100 128GB SATA 2.5” 7mm SSD + 9.5mm Adapter (CT128MX100SSD1) £54.98
1 x Corsair Fan, SP120 PWM Low Noise High Pressure Fan 4 pin, Dual Pack (CO-9050012-WW) £25
1 x NZXT CB-LED20-WT 24x White LED Sleeve - 2m £13.99
1 x BitFenix Alchemy 24Pin ATX Extension 30cm - sleeved blue/blue £7.49
1 x BitFenix Alchemy 6Pin PCIe Extension 45cm - sleeved blue/blue £6.98
1 x BitFenix Alchemy 8Pin PCIe Extension 45cm - sleeved blue/blue £6.98
1 x BitFenix Alchemy 8Pin EPS12V Extension 45cm - sleeved blue/blue £5.99
Total : £558.96 (includes shipping : £8.00).
The rest of the spec Includes an i5 3570k And a Gigabyte Windforce 7950. Will post more pictures as the build progresses.
YOUR BASKET
Spec looks awesome, can't wait too see it build, I'm personally have a small man crush on the Phanteks cases.
