I'm thinking about fitting a front fan at the bottom in order to get more airflow through the bottom of the front of this case, where my HDD and SSD are mounted. Temps are fine, but them being in a mostly enclosed area with no cooling niggles at me.
It's clearly stated that this case allows the fitting of 120mm fans at the front. There is a frame at the front for fans. The problem is that the mounting holes on that frame are spaced for 140mm fans only. The mounting holes on the 120mm fan I have line up with some vertical slots in the Pro M mounting frame, but those slots are wider than the fan holes and so can't be used for mounting the fan unless you use bolts sourced from somewhere.
Am I missing something or is the manual wrong and the case doesn't support 120mm fans at the front?
