Entourage and Exchange 2007
4 Dec 2002
Bourne, Lincs
Does anyone know of a link to show which versions of Entourage are compatible with Exchange 2007 SP2?
I know the IMAP is setup correctly as Windows Mail connects fine, however I get "command can not be understood" style messages from Entourage.
I need to dig out what version we are on as I have a feeling its not that new, hence trying to find out what verions work with Exchange 2007
Thanks
Kimbie
Just upgrade to Snow Leopard (assuming you aren't on PPC macs). The built in Exchange integration works better than Entourage does anyway. Yes it is a bit tedious that you have to open Mail, iCal, etc seperately, but it does work, and Snow Leopard is blisteringly quick.
