Entropay with US Store
16 Apr 2007
UK
Hey all,
I finally got Rock Band today, and I'd like to buy some songs from the US store.
I have found that if you use Entropay.com, you are able to use your card on the US store :)
However, it asks for a type of identity such as a driving licence...
So my question is... I have a provisional driving licence, will that number work? :p
What I mean is, when you become a full driver, does the number change?
Thanks ^^
Marky
Hey all,
Thanks ^^
Marky
Try the number. Entropay check each account, if they don;t like the look of your ID and stuff, they will happily ask you to fax in additional photocopies of the item. (I had to fax off some stuff as I didn't give Driver's License online).
Shouldn't be an issue. I had no issues creating an account and have recommended it to loads of people who have done it all online as well.
But in answer to your original question, it has been so long since going from Provisional to Normal License I can't remember if the numbers were the same :(
rp2000
rp2000
Just tried it and it seems to have worked :) Thanks again buddy :) Time to get back to rocking out :p
rp2000
I might resort to this, I'm getting annoyed waiting for Pain and Everyday Shooter :mad:
Just be carefull I currently have £18 stuck on entropay I am unable to spend :(
Ended up being a complete waste of time & money for me :mad:
Just a quick note - it all worked fine :) Added cash to the account and put it straight in my US PSN wallet ;) Downloaded some songs... Rock Band is one good game :p
Long story short I couldn't put the money onto any of the UK or US PSN stores, I contacted Entropay and they said it will take a couple of days to verify. Still couldn't do it and now my Debit Card has expired I can't put the money back into my account so I'm stuck.
Contacted Entropay several times with no response. This has been going on since August :(
Did you use "ENTROPAY USER" for the card name?
