Entry level bundle OC
16 Aug 2004
Hi,
Probably a lot of these posts, though couldn’t see many recently.
I havent gamed on a PC for over a decade and have no idea where tech is now.
My windows machine is old and slow and there a few PC games I’d like to play like WW2online and emulation (currently using my MacBook). I’ll use my ps4 (and 5 when it’s more mainstream) for proper gaming.
Looking at the entry level bundles..any recommendations or adjustments to build?
IMO this is the entry level into a new gaming PC.
My basket at OcUK:
Total: £884.58 (includes delivery: £11.70)​
This build uses quality components and will be an excellent PC for the forseeable future. I do not see any value into buying a cpu below a 12100f and if you buy new then going below an RX 6600 gpu means you are making severe compromises and I would not recommend it. You can problably save £50-100 on the above build if you go for cheaper mobo and other components but if you do not state a budget we do not have much to go on.
£90 (incl. VAT)
£74 (incl. VAT)
FREE DELIVERY
